So, I added a new decice on the sync chain and it changed the title bar color of Brave on every Windows device in the same chain. So far I used to have the same color as Windows.
It seems that this option is now gone? In the Chrome version there is still a version to use system colors
However, I don’t think I ever once had the option to use the device colors.
I do have a screenshot of Brave from a couple months ago (and apparently 7 months ago I had Micah capable titlebar with translucency just for Windows 11 I enabled via flags, which some update also removed some time ago, and the flag as well for it), and when I did have my titlebar color enabled in Windows, it was not doing this even then:
Can a dev confirm if Brave ever had this? I faintly remember being told Brave uses the native Windows title bar API, which could be why if I had to guess. (EDIT: Just dawned on me I think that was in reference to vertical tabs only.)
