Umbrel.local works on my mobile device but not desktop
I can access umbrel.local on my Android device. I used to be able to access on my HP laptop but now it “can’t be reached”
  1. Must be using an Umbrel device
  2. Set up Umbrel via home wifi
  3. Go to umbrel.local
Should bring up the login page for Umbrel
v1.80.113
It sometimes works on the desktop but rarely. It hasn’t for a couple weeks.
@tadashi03
Manually set a static IP address for the Umbrell device. So, you would connect to (for example):
http://192.158.0.55 instead of using http://umbrell.local
In BB settings, set the upgrade of HTTP → HTTPS to standard (or lesser grade).
Edit your computer’s hosts file; add a line:
192.158.0.55 umbrell.local
Search online, for suggestions re dealing with Local Area Network devices - settings of your computer’s Operating System - there may be some switch to throw.
Everywhere I have encountered the problem, I test with or use Firefox.
Hello, thank you for the help. I was able to access it using the IP address.
