Description of the issue: When using iframes to load a twitch stream, it only shows a black screen for the video stream. The twitch UI loads in, just not the video/audio.
Paste this script into the console on any regular website (e.g. google/twitch/wikipedia), it will create an iframe as seen below and load a twitch channel. feel free to swap out the twitch channel name in the script to any streamer you want.
Brave is up to date
Brave 1.79.126 (Official Build) (arm64)
Chromium: 137.0.7151.119
Macos 14.1.1 | M2 Pro Additional Information:
I found this issue out as I use this extension for twitch https://previews-app.com/ - it creates little preview windows for streamers when you hover over their name, but it has since broken. I think Twitch might be attempting to block Brave as a whole, possibly in some kind of get back for Brave blocking Twitch ads by default, I’m not sure. All I know is, since Brave made that announcement about it blocking twitch ads, iframes no longer work in Brave. I use Twitch turbo, so in theory no ads should attempt to load across the entire site if its something to do with ad delivery.
No they don’t load on other websites. for example, all streamers typically have a StreamElements page, where the stream is embedded. StreamElements is major/official partner with Twitch, so it shouldn’t be broken here - but it is when using Brave.
the reason I provided the script was just to make it easily reproducible for people here on the forums.
I found this thread by searching around the internet after being suddenly unable to play embedded Twitch streams in a website since yesterday in Brave. In Chrome, Edge and Firefox they work properly. There’s a GraphQL endpoint that is called in Twitch’s embed iframe to get a PlaybackAccessToken and apparently if your user agent is “Brave” it responds with server error. If you set the user agent to Google Chrome or Test or anything else, you get a playback token. I contacted Twitch support yesterday to debug the errors some of my webapp’s users were seeing and they recommended that I try a supported browser, which is when I discovered this.
It looks like embeds now load and work on brave, but autoplay seems to be broken.
For example ifraem on: https://allstreams.tv/twitch/kaicenat seems to autoplay on Chrome, but not in Brave.
