NOTE: Any “one-liner” or topics requesting support or reporting bugs that do not make an effort to include as much of this information as possible will not be responded to. Repeatedly posting as such is grounds for banning._
At this test site to see what is leaked about the user/browser, https://coveryourtracks.eff.org/ you can see that the user’s originating timezone and screen resolution are able to be known.
Go here in Brave, release, nightly, etc.
Your TZ, screen resolution, and a slew of other properties are exposed (GPU, etc)
Randomized or false TZ information should be shared with the testing site, along with randomized or slightly modified resolution information and other information.
Version 1.23.13 Chromium: 89.0.4389.72 (Official Build) nightly (64-bit)
