Top left of screen is unclickable in fullscreen mode
Description of the issue: In fullscreen mode, elements near the top-left of the webpage (e.g. navigation links) are unclickable. The cursor does not change to a pointer on hover, and clicks do not register. Right-clicking the affected area shows the browser’s title bar context menu instead of the webpage’s, indicating the title bar hit/drag region extends too far down into the page content. I only noticed this today.
  1. Open any website with clickable elements near the top-left of the page (e.g. https://app.hyperliquid.xyz — the “Trade” nav link)
  2. Enter fullscreen mode (Ctrl + Cmd + F or green button)
  3. Try to click the top-left navigation link — it will not respond. Right-clicking shows the browser context menu, not the page context menu.
Expected result: All page elements should be clickable in fullscreen. The title bar hit region should not overlap webpage content.
Brave Version: 1.89.132
  • macOS, MacBook Pro with notch, running in clamshell mode on an external monitor
  • The issue does NOT occur in maximised (non-fullscreen) window mode
  • The issue does NOT occur in Google Chrome fullscreen on the same machine
  • The issue does NOT occur in Safari
  • “Always show toolbar in full screen” toggle (on or off) does not affect the behaviour
  • The issue appears to be caused by the invisible title bar drag region extending too far into the rendered page area in fullscreen mode
@shdowhdo
Probably related:
‘Traffic light flag’
‘Traffic light flag - #4 by 289wk’
I’ve been experiencing this as well, and it started roughly around the same time you posted this. Personally, I’ve been using brave since 2022, and I’ve had this issue before, but I can’t rememer what resolved the issue last time.
Same issue here on macOS. When Brave is in fullscreen mode, there’s a dead strip roughly 2 cm tall spanning the full width of the screen at the top of the page — elements inside it aren’t clickable. For example, on YouTube the YouTube logo in the top-left is unclickable in fullscreen, but works normally as soon as I leave fullscreen. Chrome and Safari in fullscreen behave correctly on the same machine.
Two observations that match the original reporter’s title-bar-drag-region hypothesis:
  • The cursor does not change to a pointer when hovering over affected elements.
  • Right-clicking inside the dead zone brings up the browser’s title-bar context menu instead of the page’s context menu.
Additional data points:
  • Reproduces on the internal display alone (laptop open, no external monitor).
  • Reproduces with an external display attached as well (both extended and clamshell-style setups).
  • Started roughly 14 days ago, likely after a recent Brave update — I didn’t have this issue before.
  • “Always show toolbar in full screen” toggle has no effect either way.
System info:
  • Brave 1.89.137 (Official Build, arm64), Chromium 147.0.7727.102
  • macOS 26.4.1 (Tahoe, build 25E253)
  • MacBook Pro 14", M3 Pro (Mac15,6) — has a notch
  • Built-in Liquid Retina XDR + occasional external ultrawide (3440×1440)
Given that it reproduces on the internal display alone and “Always show toolbar in full screen” has no effect, this looks like a Brave-specific regression in the fullscreen title-bar hit region — the non-client area appears to extend ~2 cm into the page content.
