How do we can toggle Responsive Design Mode. I did not find a hotkey designed to it at: https://support.brave.com/hc/en-us/articles/360032272171-What-keyboard-shortcuts-can-I-use-in-Brave-
E.g. For chrome it is ctrl+shift+i
it’s same
by the way anything related to the core browser will be equal to chrome
it work fine here in linux
It works for windows 10 as well
ctrl+d is to put up a bookmark for me.
Just tested. But tanks you for the suggestion. I’ll keep on trying.
No its my mistak actually!
You can get that with Ctrl + Shift + m
ctrl+shift+m is to set up a new profile.
Unless the developer tools window is open…
good one @megaspaz Thanks also @Rohit552 good suggestion
So lets put it together real quick.
Open console with ctrl+shift+i
if open ctrl+shift+m to toggle to mobile mode
easy peasy if ya know
AND THIS IS WHY I’D ASK:
READ TO THE ALMOST END: FAR CRY 3 YOU GET WITH THIS ALSO FOR FREE
Have fun
Forgot this
option
