This site does not keep me logged in
Despite having set cookies from community.brave.com to always be saved, I have to sign into this site every time after I restart Brave. Is this by design or have I forgot some setting?
EDIT: I have found the solution. I had enabled “clear cookies and site data” in “clear browsing data on exit”. It is very confusing because there is another option with the same name in the cookies panel that does not delete cookies from whitelisted sites. The first option does.
It is not by design, something is wrong in your settings.
Thank you for your reply chh, do you have any suggestions as to how I might fix this?
