Description of the issue
There is no sound available on any MKV file while using the torrent streamer in Brave. The sound bar is greyed out, simply not an option
Exact URL of the website in question
Any torrent site
Did the issue present with default Shields settings? [Default states are: Block: Ads/Trackers, 3rd Party Cookies, 3rd Party Fingerprinting Allow: Encrypt Connections enabled (HTTPS), Scripts] (yes/no)
Yes
Does the site function as expected when Shields are turned off? (yes/no)
No
Is there a specific Shields configuration that causes the site to break? If so, tell us that configuration. (yes/no)
No
Does the site function as expected when using Chrome? (yes/no)
There is no torrent stream option in Chrome, so not really applicable in this case.
What Operating System and Brave version/Build are you using when you encounter the issue?(See the About Brave page in the main menu)
Windows 10
Version 0.63.55 Chromium: 74.0.3729.131 (Official Build) (64-bit)
