I’m trying to sync Brave saved bookmarks between my phone (Android) and my laptop (PC). My laptop lost all saved bookmarks between my phone and home desktop due to a necessary reboot of the OS.
I want to sync all the bookmarks I have in my phone to the laptop.
Anyway, every time I try and set up Sync, the instructions are as follows: “Start by opening the Brave browser on the device you want to sync from and go to the Menu, then select Brave Sync. Choose “Start a new sync chain”
And there is NEVER a “Start a new sync chain” option under “Sync.” The ONLY options after I click on “Sync” is a list of devices on the sync chain (Which has only my desketop listed). Then, when I click on “Add New Device,” then click on “Add a Computer” the ONLY options are “Enter the sync Chain Code” or it gives me an option to scan a QR Code (Not sure how on earth one scans a QR code from a computer).
When I click on settings on my laptop, there is NEVER a “I have a Sync Code” option.
I’m not sure why this always (and I mean ALWAYS!!!) happens to me when I’m trying to troubleshoot things on my computer(s), but it is inevitable that when it tells you to go into “this”, then click on “that,” “that” NEVER shows up as an option. I guess we all have our cross to bear, and this happens to be one of mine.
Thank you for your help in this matter.
