Description of the issue: The thumbnails for some websites are a bit distorted.
Occurs on the home page and in the Brave Rewards window.
Actual Result:
Brave Version(about:brave):
Version 0.56.15 Chromium: 70.0.3538.110 (Official Build) (64-bit)
yes
Ubuntu 18.04.1 LTS
Hi @OutrageOrange, thanks for reaching out!
So first thing I would try is to check and see if Hardware Acceleration is on (and disable it if so). Option is located in Settings --> Advanced --> System
Let me know if that helps the problem. We also have this open issue here which may be related:
Sorry for not replying yesterday,
yes that fixed the problem.
Thank You!
