Technical problem
The browser closes all tubs that were open. This doesn’t always happen, but often.
  1. I leave the tabs open and close the browser
  2. Then I go into it again and it closes all the tabs.
I want the browser to stop closing tabs on its own
Brave 1.77.101, Chromium 135.0.7049.115
Mobile Device details
Realme GT2 pro, android 14
@Elsa
Maybe toggle the Close tabs on exit switch:
And after each setting of that switch, do a complete Exit / Quit of the Android device - in order to knock the dust out of the setting? (Is a theory.)
I have this item disabled…:thinking:
@Elsa
And you flipped the switch a couple times, doing a complete Exit / Quit of Android after each throw of the switch . . . before finally setting the switch to OFF . . . correct?
Excuse me, at first I didn’t understand what I needed to do, now I did as you said. :grin: I’ll see if it worked.
@Elsa
You are OK. Keep plugging away - it might work.
