Tabs not restored when closing Brave on iPad with external monitor
When using the Brave browser on an iPad with an external monitor connected, tabs are not saved if the browser is closed using the :cross_mark: (close) button.
  1. Connect an external monitor to an iPad.
  2. Open Brave Browser.
  3. Open one or more tabs.
  4. Close the Brave browser window using the :cross_mark: button (window close button).
  5. Reopen Brave Browser.
Previously opened tabs should be restored or saved, even when Brave is closed using the :cross_mark: button while an external monitor is connected.
Actual result:
All open tabs are lost and not restored after reopening Brave.
[Please fill in your Brave version here]
Mobile Device details:
  • Device: iPad
  • OS: iPadOS 18
  • OS Version: iPadOS 26.2
  • External monitor: Connected
This issue only occurs when an external monitor is connected.
When using the iPad without an external monitor, tabs are saved correctly.
Can you tell me by what method you’re using to link your iPad to the external monitor? Is it a simple iOS screen extension or mirroring? Or using a third party software?
Closing the window via the red X button in iOS 26 is equivalent of closing a window on desktop, the tabs associated with that window will also be discarded (an external monitor is irrelevant to that behaviour). Tabs are restored to a particular window when that window is closed because the app itself is terminated by either the OS or by you doing so yourself in the app switcher
