Does the Brave Wallet sync across devices? I back it up from one device and entered the code on the other but I can’t immediately tell if they’re syncing between each other or if that was just a one-time copy/paste style action. Does anyone have a definitive answer? If it is truly syncing I would like to expand this to more devices. Thanks, Alex
@WeirdAlex03 in short, no. Those method is not for sync your wallet. It’s only make you able to “use” the same wallet across devices.
The team is working for wallet sync, IIRC.
Alright, I’ll keep an eye out it. Thanks!
