I have a small suggestion, to add a couple more tags, some Topics I see a lot of is definitely YouTube and maybe Google, you might also add Social Media and/or adding the big ones, e.g. X-Twitter, Meta
My main point of this post on the tag side of things is for YouTube though, there are SO many issues concerning YouTube specifically (maybe even just create a YouTube category
Another thought I had was pointing out more about the Community Search Function, just using the Standard Search Magnifying Glass at the top, I personally have found it useless, but if people click on the little FILTER button in the search field, and/or go directly to https://community.brave.app/search?q=test and use filters and/or more specifically choose “Sort by” can be a lot more helpful than the default just from the standard basic search.
Again, as pointed out in the past, people just want to come and vent and get an answer and not do any research, but I’ve been around for awhile, not always consistently but I never noticed those different search options before until more recently and it’s almost life changing (Particularly: “Latest Post” for recent issues)… if the common or new user comes by and DOES try to find something but not click the filters and customize it a bit more and realize there is that extra help AND just get the standard whatever results in their search that’s often outdated by months to years, they almost have no choice BUT to start their own topic.
Anyway, just some thoughts ![]()
