Spell Check Problem
I have been using Brave Browser for several years on Linux Mint OS with zero problems but about 2-3 months ago my Spell Check started to shut off with the button still showing ON ….. I told by a third party to go into Settings and turn the button from on to off and it would work again …. I did and they were right BUT in a couple of days it shut down again …. this kept happening on and off again up until now …..
I searched on the forum and found about 4-5 persons with the same problem … no real answers were given to solve the problem and the topic was closed …… Brave is set to auto-update by my OS …. here is my Brave info:
Brave 1.86.139 (Official Build) (64-bit)
Chromium: 144.0.7559.59
My laptop info:
Thank you for any help you may provide
Mike
As far as I know, Brave and all Chromium browsers get their dictionary from the OS itself.
What is other Chromium based browsers currently doing?
(PS, your OS has not updated Brave in a while, we are on 1.87.191 currently, your version is from December of last year).
Thanks for your reply … I am currently checking into why Mint did not update Brave since last year …. I keep a copy of all Mint updates by year … I did an Update Command in the terminal and discovered that Brave does not have the following “ NO_PUBKEY 0686B78420038257 “ ….. not sure just exactly what that means …. but I’m research that also …..
Ahh, this sounds familiar!
Check out that thread, another Mint user too. Check the bottom reply, it has a fix which is re-run the curl command.
I went to the Brave download page and copied the terminal command for the Key-ring and installed it again ….
sudo curl -fsSLo /usr/share/keyrings/brave-browser-archive-keyring.gpg https://brave-browser-apt-release.s3.brave.com/brave-browser-archive-keyring.gpg
Did a sudo apt update && sudo apt upgrade and it seemed to remove the warnings so it appears to have solved the problem but only time will tell …. LOL
Thanks for your help I appreciate it ….
That likely is all that would be needed to fix it.
It appears someone else on GitHub found that sudo apt install brave-keyring also fixed it (though re-running the script you ran seems to achieve ultimately the same thing).
Let me know how it goes, if it continues working or not. (I’m just a user but don’t mind helping once in a while.)
Will do sometimes it may take a few days as it is pretty sporadic ….. ok so far … LOL
I found this a bit interesting as I save all mint OS updates from when I started using it in 2024 ….. used Zorin OS before that …… here is what I found out …..
Brave Browser Updates On Mint OS
Started recording Mint updates on 9-9-2024
First Brave update was: - 09-12-2024 ver 1.69.168
2025
Version ——- Date
1.84.135 —— 11-07
1.84.139 ——- 11-13
1.84.141 ——- 11-19
1.85.111 ——– 12-04
1.85.116 ——- 12-12
1.85.117 ——— 12-18
1.85.118——– 12-20
2026
1.85.120 ——- 01-08
1.85.139 ——– 01-16
Current version from keyring change: 3-1-2026
Brave 1.87.191 (Official Build) (64-bit)
Chromium: 145.0.7632.120
Just received my first update today it is now 1.87.192 from 1/87.191 so we’ll see how it goes …. spell check is still working ….. :joy:
