I’m getting the same plus 3 more, but that shouldn’t matter when the shields are down, right?
Correct, Can you try,
Close all Brave windows, I’m not sure where in ubunutu, but in windows. Locate the Preferences file, and just rename it.
In windows (for example):
%userprofile%\AppData\Local\BraveSoftware\Brave-Browser\User Data\Default
rename file Preferences (Preferences2)
Okay in Linux: (open a terminal)
cd ~/.config/BraveSoftware/Brave-Browser/Default
mv Preferences Preferences2
Then relaunch Brave
Hey, I’m sorry about the delayed response. Work gets in the way sometimes.
I tried renaming the Preferences file but it didn’t fix the issue.
Here’s another site with the same issue: https://tinyhousegiantjourney.com/2017/11/08/monthly-expenses/
