ISSUE - When importing data from chrome to brave you get the “please close all chrome windows” error message. You promptly close all windows and try again to only receive the same error message once again.
SOLVED - hit control, alt delete and open task manager, go to advanced and then scroll down to find all of your extensions that are still active. Close these and try the data import once again.
This was solved on Windows 10.
