Some sites will not load at all until I disable ad block then they will load
As you know ad blocker blocks ads. But some of the sites are designed in such a way that it won’t work until you disable the ad blocker although the frequency of ads in those kind of sites are low but they still force you to see their ads. Hope you got your answer. Have a nice day.
What websites can’t you open without turning Shields off?
I can investigate the issue, just need some sample sites to debug. @Magical_meadow
