Using Brave as admin helps, as stated here https://community.brave.app/t/ad-block-isnt-working/546423/2?u=husarior, but if I open Brave from a taskbar, as always, it no longer goes as admin, so shields doesn’t work. While using the browser as admin brave://components/ update, but even after updating these, if I open Brave without admin privileges, there is an error in every component.
I was installing fresh Win10 on this machine many times and this problem started just now. I never had a problem like this.
How to make it work without admin privileges?
It seems like reinstalling the browser from .exe downloaded from Brave’s webside did help.
Previously I had Brave installed through Powershell (Chocolatey).
I have never done it previously and still got that problem. In my case reinstalling Brave from main .exe download from https://brave.com/download/ did help. (Previously installed through PowerShell – Chocolatey.)
But just in case I will never try to open Brave as admin.
Thank you for the answer nonetheless.
