"Shield" problem as a webmaster
I’ve just switched over to “Brave” since as a webmaster it’s bad for the website visitors statistic if also me get tracked. Before I used “Chrome” and there I could block myself from getting tracked in analytics, and with “Ublock” I could stop everything else.
To change the SEO backend on my wordpress sites, I needed to shut off “Ublock” and that was ok.
However in Brave, there is no such option.
Now to change the SEO setting (like Meta and Description) I need to completely shut the Shield off.
  • which is very annoying.
Is there a work around, so that I can may be put in a script that will allow everything within the path “/wp-content/plugins/all-in-one-seo-pack/” or similar to run?
  • so I don’t need to shut it on and off every time?
I know there is a some “filter” you can add, but Im not sure if this is possible?
It really should be…
Hope anyone knows a way around this.
//M
