Search function within settings freezes for five seconds and then stutters
Upon first use of the new search field at the top of the Settings page, after typing about four or five characters (sometimes as few as three), everything freezes for about five seconds. Then, the input resumes (if one had continued typing anyway) and eventually some results appear but only for about one second before disappearing completely for a few seconds while a “processing” indicator spins. Only then do final results appear and stay put.
In other words, it’s a quite jerky process.
It does not happen for subsequent searches as long as the tab isn’t closed. Opening Settings again later, even within the same session, triggers the jerky process again.
I suppose it’s because some index is re-built each time. But from my point of view, it worked fine before and now… not so much.
Origin Build type
Standalone
Operating System and Brave Version
[Brave 1.93.35 (Build officiel) nightly (64 bits)]
Chromium: 149.0.7827.59
Originally reported as:
[Brave 1.93.24 (Build officiel) nightly (64 bits)]
Chromium: 149.0.7827.54
I’ve always had slow Brave settings search, due to how the results are found. They are not indexed, rather, they are searched the same way that pressing ctrl+f and searching on a website is achieved.
The interesting factor is that it was faster before now then before.
Can you see if:
  • Testing in a new Brave Browser Origin profile is faster?
  • Testing Brave (Release) is faster?
  • Testing Brave Nightly/Beta/Origin Nightly/Origin Beta (any of the four test browsers).
Also Brave Origin (Release) has only recently released, can you try the release version, as it’s generally more stable than Nightly.
Brave has been my main desktop browser for eight years and I’ve never experienced any slowness when searching in settings.
But the symptom I described is not slowness or sluggishness. It’s the interface being completely unresponsive for several seconds, followed by a display / hide / re-display cycle that makes it look like the system is having a spasm. Or is being indecisive.
Also, even if there is no indexing, there is clearly something very different from using “Find in page” because the search in settings doesn’t merely bring you to the next occurrence of the search string; it presents a sort of collage of all the pertinent settings.
The issue I’m experiencing may not be unique to Brave Origin. However, it is clearly related to a change first seen in Chromium, whereby we don’t have to press Ctrl+F anymore, as the search field is already open and focused when we get to the settings page. But I have not seen the freezing symptom in Chromium, even on the same machine.
Hello,
Can you please go and test the other Brave Browser variants and a new Brave profile as suggested? This will help us to determine the root cause of the slowness. Additionally, providing a screen recording of the search progress is helpful to determine differences (for you) between Brave Origin and Chromium.
Giving theories does not necessarily determine what is causing the issue, rather trial and error is the best approach to lead you to a solution.
To be clear, there is no noticeable difference (to me) when searching within Chromium settings on Ubuntu Linux on:
  • Brave (Release)
  • Brave Origin (Release) (Using current profile, and creating new profile).
  • Chromium
My suggestion is that you test at least the above Chromium variants, and report back in screen recording form.
Thanks!
