Description of the issue: Attempting to search with a different engine will search with the default engine after switching tabs.
- Either add a custom search engine or choose one of the included engines that is not your default.
- Activate the engine chosen in step 1 by typing its shortcut and then pressing Space or Tab (as per your setting in
brave://settings/searchEngines).
- Enter a search query.
- Open or switch to another tab.
- Switch back to the tab with your search query.
- Press Enter to search.
Expected result: A search is performed using your chosen engine.
Actual result: A search is performed using the default engine.
Brave Version (check About Brave): 1.80.122 (Official Build) (64-bit) Chromium: 138.0.7204.157
Additional Information: A potentially related issue was brought up in the topic “Search bar searches deleted query after switching to another tab”.
Yeah I see this behavior as well. Thank you for reporting – I’ve opened the following issue on our github for this:
This issue is still present in Brave 1.81.135 (Official Build) (64-bit) Chromium: 139.0.7258.127.
