Schoology LMS Gradebook Will Not Load
Description of the issue: School Learning Management System Gradebook will not load, but all other pages within their website will load.
Exact URL of the website in question: Unable to post a direct link due to users needing an account
Did the issue present with default Shields settings? (yes/no) Yes
Does the site function as expected when Shields are turned off? Yes
Is there a specific Shields configuration that causes the site to break? If so, tell us that configuration. (yes/no): Shields on it will not load, Shields off, it will
Does the site work as expected when using Chrome? Yes
Brave version (check About Brave): 1.81.135
If you could provide a test login privately and directions, I could take a look at it?
