Running Brave on mutliple computers
is there anything special I need to do to use my Brave account on another computer? I assume just download , install, and sign in and the two computers I use (work and home) should sync with the rewards etc. Just didnt want to mess up what has been working so far with brave…thanks
@bbrown9506,
There is no “Brave account” for you to sign into.
If you want to “sync” Rewards, you’ll need to verify your wallet with Uphold/Gemini on your first machine, then do the same on any additional devices (up to 4).
If you want to Sync your data, simply use Brave Sync:
Thanks–I guess I was asking about syncing rewards and you answered that so thanks and Ill try that now
