Right click to run Flash
Im not sure how to describe this but certain banners in the site needs Flash. I redownloaded Flash a few times and it worked fine on Chrome but keep on having the same problem on Brave.
I allowed Flash to run on the website but when I click to run Flash, it shows “Right click to run flash”, as seen in the screenshot below. When I follow the prompt and click run plugin, it does nothing
Banner(?) should load properly once Flash is enabled/allowed to run.
Any time I try to access the page.
Brave Version(about:brave):
Version 0.59.35 Chromium: 72.0.3626.81 (Official Build) (64-bit)
Yes
@ohnoes Can you share the site in question?
Thanks for the reply but it seems to be working now after my computer updated? Im not sure how but the problem is solved!
