Since some builds ago, when right clicking text, the caption to search on google, shows “&,” in front:
Hello friend, the problem is fixed. The problem basically is that the order is changed (also “amp”).
The change will be present in the next build (but was fixed the first day). Also, approximately about 500 translations have been improved.
I recommend you use “Spanish” instead “Spanish (Spain)” because is very advanced (97 %).
Thanks.
