Right click back arrow and split tab
I frequently find when parsing documentation I need to duplicate the current tab, then in the first tab go back using the back arrow, then create a split view and add both tabs to it.
It would be a productivity saver if you could right click the back button and select an old page to split with the current page. Same functionality if with the forward arrow if possible (although maybe not used as much, but seems easy enough to add once done for the back arrow).
