as mentioned above i lost access to brave wallet
and dont have recovery key
is there any way to restore wallet/make new one
@Hrumn,
Can you tell me how you lost access to your wallet? Additionally, when you say you donât have a recovery key, do you mean you didnât save/create one?
Lost Access to wallet during brave update
Also i didint Created key
czw., 28 lut 2019, 22:24 uĆŒytkownik Mattches via Brave Community brave@discoursemail.com napisaĆ:
@Hrumn, sorry for the late response.
To which update are you referring to?
The update in version to v0.60.45, or the upgrade from Muon (old Brave build) to new Brave âcoreâ build (with chromium UI)?
From Old Brave to New Brave if i remember good
Thatâs what I thought, just wanted to make sure we were on the same page.
So the next question is whether or not you still have your wallet data on your machine. To do this:
- Navigate to the appropriate directory based on the Operating System youâre using
Windows -
~[Your User Profile]\%AppData%\Roaming\brave -
macOS -
/Users/[Your User Name]/Library/Application Support/brave -
Linux -
./config/brave
Windows -
- Confirm that this folder does exists - if not, we may be out of luck
- If it does, ensure that it contains a file called
ledger-state.json
Let me know what you find out and we can continue with next steps for importing your wallet.
Got both Said Folder and file
Sorry for the late reply.
Now that you have both of those:
- Install Brave Muon (you can get the binary from our Github)
- Once Brave Muon is installed, you have two options
- Open Brave Core (new), go to
[Menu] --> Bookmarks --> Import Bookmarks and settings, select Brave (Old) from the drop-down box and ensure you check theBrave Paymentsbox on the data to be imported. - Alternatively, once Brave Muon is installed, launch it and follow instructions to backup wallet data from within the browser - then resto re it in Brave Core.
first method failed for some reason
second one worked
big thx for help
and donât worry about late responses
since i probably sleep when you workâș
Glad to hear it!
Thanks for your patience!
