Request a WHITE-CURSOR either by default, by a setting option, or by a brave-flag; for better visibility
Request a WHITE-CURSOR either by default, by a setting option, or by a brave-flag; for better visibility.
Blue cursor when editing in location-bar is not visible enough (for me) at night, in low light (unless I temporarily crank up screen brightness), with Night-Mode enabled (which I use 95% of time anyway day or night), in both normal & private tabs.
The background of location-bar is black and purple respectively (ok by me, text is white); but cursor visibility for these BGs are bad & worse respectively.
Using the menu version of find-in-page, the dialog for that field uses a white cursor: GOOD.
I prefer to SLIDE across the space button to move the cursor in the location, since it keeps my finger closer to backspace & Go. Yes: if I slide on the location-bar instead I get a bubble showing cursor in context of near-text, which is a little larger, so a little more visible, but still poor.
In ios-settings, keyboard, enable slide to type.
In brave enable night-mode, goto dark room. In sequence try normal-tab, private-tab and find-in-page from the menu. In the location-bar or menu/FIP:search-field type random text like “brave-location-cursor”.
Now hold finger down on space button on the keyboard, to move cursor left and right thru that random text. Screenshots show the menu-FIP white-cursor (good) & safari’s private-tab location white-cursor (good), and brave-private location-bar using slide vs bubble blue-cursor (bad). (No screenshot for brave normal-tab: background is black which is not as bad as private-tab’s purple, but still poor visibility using the blue-cursor.)
Ability to configure a white-cursor, to see it better in night-mode and low-light environment.
always
ios: 18.7.6
brave browser: 1.86 (144)
old & closed issue by someone else (Feb 2021); bright-yellow would be better than current blue, but I’d still prefer white:
Thanks for pointing this out, I’ve opened an issue to track: https://github.com/brave/brave-browser/issues/53802
