Periodically new tabs won’t render at all and existing tabs are stuck at their previous size. The only way to get either to render is to drag the tab out of the window into its own window. Resizing or refreshing has no effect. This behavior occurs with hardware acceleration enabled and disabled.
Opening tabs on a new window works as expected.
Cannot consistently reproduce. It may be related to sleep mode but I think it’s also happened a few times even without sleep. Chromium and Chrome with the same hardware acceleration settings do not act the same.
(I scrubbed the page contents of PII before recording)
New tabs should always render and existing tabs should resize with the window.
Inconsistent. May be related to sleep mode. Happens 2-3 times a week. (Using computer for 40+ hours).
Arch Linux
|Brave|1.22.70 Chromium: 89.0.4389.105 (Official Build) (64-bit)|
|Revision|14f44e21a9d539cd49c72468a29bfca4fa43f710-refs/branch-heads/4389_90@{#7}|
Graphics Feature Status
- Canvas: Hardware accelerated
- Compositing: Hardware accelerated
- Multiple Raster Threads: Enabled
- Out-of-process Rasterization: Hardware accelerated
- OpenGL: Enabled
- Rasterization: Hardware accelerated on all pages
- Skia Renderer: Enabled
- Video Decode: Hardware accelerated
- Vulkan: Disabled
- WebGL: Hardware accelerated
- WebGL2: Hardware accelerated
Driver Bug Workarounds
- adjust_src_dst_region_for_blitframebuffer
- clear_uniforms_before_first_program_use
- decode_encode_srgb_for_generatemipmap
- exit_on_context_lost
- msaa_is_slow
- scalarize_vec_and_mat_constructor_args
- disabled_extension_GL_KHR_blend_equation_advanced
- disabled_extension_GL_KHR_blend_equation_advanced_coherent
