WHY? And how to remove this?
Did you try going to brave://settings/system/shortcuts
and searching screenshot and removing what’s there?
(by clicking the little - button beside the shortcut)
otherwise I’d say it’s an OS issue.
Not sure why it was set that way – maybe an installed extension? On my end that shortcut is blank by default.
Either way @User.1.000.000.000 is correct here – change the shortcut in the brave://settings/system/shortcuts page.
