Regression: Background audio requires manual resumption and simultaneous YouTube playback across tabs no longer works on iOS
Brave version: 1.96.62
Operating system: iOS 27.0.1
Enable Background Audio: Enabled
Description
Brave’s background audio behavior on iOS has regressed over time. Both automatic background playback and the ability to play audio from multiple YouTube tabs simultaneously have been affected.
Previously, YouTube audio continued playing when Brave was minimized or the iPhone screen was locked, without any manual intervention. There could be a brief interruption, but playback resumed automatically. The Orion browser on iOS currently offers similar behavior.
In a subsequent version of Brave, background playback stopped resuming automatically. To continue playback after minimizing Brave or locking the screen, I had to manually press the Play button in the iOS Control Center or on the Lock Screen.
At that time, manually resuming playback for each individual YouTube tab made it possible to play audio from multiple YouTube videos simultaneously in the background, even with the screen locked.
In the current version, Brave 1.96.62, this workaround no longer works. Only one YouTube tab can play audio in the background, and playback still requires manual resumption using the Play button in the iOS Control Center or on the Lock Screen.
Steps to reproduce
  1. Open YouTube in Brave on iOS.
  2. Start playing a video in the first tab.
  3. Minimize Brave or lock the iPhone.
  4. Manually press Play in the iOS Control Center or on the Lock Screen to resume playback.
  5. Open a second tab and start playing another YouTube video.
  6. Try to resume background playback for the second video.
  7. Observe that simultaneous audio playback from multiple YouTube tabs is no longer possible.
Expected behavior
  • Background audio should continue or resume automatically after minimizing Brave or locking the screen, without requiring manual intervention.
  • Multiple YouTube videos in separate tabs should be able to play audio simultaneously in the background, including when the iPhone screen is locked.
Both behaviors were possible in earlier versions of Brave, although the ability to play multiple audio streams required manually resuming playback for each tab.
Actual behavior
  • Background playback does not resume automatically; the Play button must be pressed manually in the iOS Control Center or on the Lock Screen.
  • Only one YouTube tab can play audio in the background.
  • The previous workaround of manually resuming playback for each tab no longer enables simultaneous audio playback.
Environment
  • Brave 1.96.62
  • iOS 27.0.1
  • Enable Background Audio: enabled
Could you please investigate these regressions and determine whether the changes originate in Brave, WebKit, or iOS? Ideally, automatic background playback and simultaneous audio playback across multiple YouTube tabs should be restored.
Thank you!
