Reddit does not work
Reddit ads are not blocked.
on desktop or mobile? I don’t see ads on desktop using standard shields and UBO…
Would you attach a screenshot? I don’t see any ads there.
Desktop, Shield set to aggressive. See screenshot.
not a clue, since i run standard… maybe some extension?
That was my first assumption, so I disabled everything before posting this bug report.
Hey @talgeeze try re-testing with Native Cosmetics via brave://adblock see if that helps/improves
I do not have entries under this name.
My error, brave://flags
Cosmetic Filtering is enabled, native implementation for cosmetic filtering is on default.
