Received 2 different referral links for same account 😔
Received two different referral links on my gmail for same brave account.
  1. My referral Stats had disappeared earlier but now it’s fixed.
  2. While fixing I was asked to remove & readd my channels. I did so. After doing this the stats reappeared.
  3. And then I got a mail containing my referral link, comparing this mail with my previous mail I found that both mails have different referral link.
  4. Can the admin/developer please let me know which one is correct ?
  5. Note: I have 1 referred user using brave, with my old referral link.
Correct referral link which is workable to my account.
Latest Version (Android).
Email : gaonkarakshay19@gmail.com
Hope this gets solved, thanks. :blush:
@Aa-ron @steeven @Mattches
The latest referral code is the correct one!
But I have 1 referred friend with old referral code, will that referral go waste ??
I’m getting stats in my account with reference to old ref link only.
And I have have added 2 channels (twitter & youtube). Are the referral codes separate for each channel ?
@cory
They are different for each channels. I believe that the one referral will go to waste. If your friend is using the Brave browser you could tell them to uninstall and re-download with the new referral code.
sir i am getting ads but they are not counting in (ads nootification received this month) and BATS are also stucked pls help
Can you please reconfirm ?
Because my friend has already linked his browser with uphold & he even has some BATs earned in it.
Please recheck sir… @cory
Hi @AkshayGaonkar19, I see 1 ref code for your verified twitter, and one for your youtube.
So there isn’t any issue right, if I use any referral code to refer my friends & they install using it, I’ll get my referral BAT awards ? @steeven
Thanks :blush:
That’s correct :slight_smile: after 30 days of continuous use.
I referred two on JUNE but only 1 showed to
my downloaded stats and 0 installed or confirmed. Why is that? 3 months had passed and not confirmed. I’m sure they are using brave browser everyday.
Ps. I received also two referral links. @steeven
