Radio Garden HTTPS redirection loop
When a site forces an http connection (that means, the site redirects https → http), and having the automatic upgrade to https connections, then an infinite redirect loop begins.
1.
Launch Brave
2. Visit http://radio.garden/ (with the Upgraded HTTPs connections shield setting enabled)
The site never fully loads, it gets stuck in a redirect loop until the shield is manually disabled.
If you forget about it, it blocks the whole browser after a while (will not be able to load even a localhost site).
It might also be an issue if the loop silently happens over a resource (like an image) instead of the main site, but I don’t have a website to test that.
Expected R esult:
It should detect the redirection loop and stop trying to upgrade this particular connection, leaving it as http.
Always
Version 1.30.87 Chromium: 94.0.4606.71 (Official Build) (x86_64)
Yes
Additional information:
Works correctly when the shield is disabled.
I also created an issue for this here: https://github.com/EFForg/https-everywhere/issues/20140
Can you check this is resolved in Brave Nightly @radiogarden ?
not resolved in Brave Nightly
Interesting, I wasn’t able to reproduce it Nightly. But sure https://github.com/EFForg/https-everywhere/issues/20140 will help.
Here is a screen capture: https://www.dropbox.com/s/uxouy39w55yo6tg/brave-bug.mp4?dl=0
As a reference, here is mine.
