Profiles do not seperate dns settings
I am using DoH (DNS over HTTPS) and can’t access local development sites with that. .local or .test domains.
I thought the solution would be to create a seperate profile for development. However the DNS settings are shared between those profiles. So if I disable it in one profile, it is also gone in the other.
