Problems with Video playing in Brave - color saturation
I hope i can show it properly here
Info about Brave Issue happens also after updating it today to 1.98.62 official build 64 Bit
OS is Windows 11 26H2 but i had this issue also on 25H2
sometimes (mostly after i had a brave window with a video open on my second Display and i put this window on my main display) the colours of that video are MASSIVLY overcoloured
like this but when i open a new tab on that brave window and pull out this one video tab the colours get to normal like this
you see a huge differency and if i put this tab back to the other window bäm overcoloured again like hell
how can i fix that or is this just a bug or is there any setting that is maybe wrong?
@Burle17
Please edit your Original Post (“OP”) above, in order to include:
  • Brave Browser version numbers
  • Operating System version
The other browsers?
cc: @Mattches ( ← Brave Support )
I did and i hope its good and nothing is missing
Do you see this same issue occur on sites/streaming services other than Youtube?
ok i tested this on YT where it happens ALL the time
then on Netflix that has no Problems all just normal
than i tested it on Amazon Prime Video the same Problem as with YT
and finally i tested it with Disney plus her was the result a bit weird
after i put that window on my main display the same Issue but after mouse over the window the colours turned back to normal
mouse not over the window (is on the mainbar from brave )
vs mouse over the Window (cursor is on his shirt)
