As the title says, I have a problem at the time of installing the browser brave nightly, I have Windows 10 64 Bit, without further explanation I will attach a screenshot, I hope you can help me.
Regards!!
Thank you for reporting this issue, @Edixsonanm. We’re investing on our end.
IIRC, this error appears when running the general installer, which fetches update file from a server. You might try running the standalone installer to see if you’re able to install that way – note that, until we get the initial error fixed on our end, even if installation via standalone installer is successful, you may not be able to update Nightly build.
