@Joerdingd
Brave Browser = “BB”
Consider iOS / iPadOS mostly interchangeable in the following.
First, backup your data
In the iOS Files app folder, create a new, spare folder named BRAVE_FLDR_BKUP at the same level as the existing Brave folder, and into that BRAVE_FLDR_BKUP folder, place copies of all your files stored in the existing Brave folder.
Export the BB bookmarks - creating a “bookmarks.html” file, and store that in the new “BRAVE_FLDR_BKUP” folder. Also, if you use the BB Password Manager, back up your passwords to that “BRAVE_FLDR_BKUP” folder.
Back up the iPad / iPhone to a computer and/or Apple’s iCloud.
Thus, data that most BB users wish to save, is at least stored on the iPhone AND externally, but not in the BB installation path(s).
You may want to type or write down various important iPhone Settings. Make a copy of “Content Filtering” custom filters that you may have added. Disable any sync chain. Disable any automated backup service.
Such is the work that I have done before, when preparing for a complete removal of an app.
There are occasions, after a series of BB updates, I have done a complete refresh installation of BB, because of BB performance issues. (At least once per year.)
And here, after all the preceding preparations, I might do that → A thorough delete of the BB app and its data (other than what is saved in the bkup folder).
Followed by a complete shutdown of the iPad / iPhone. Followed by a fresh installation of the app in question.
Is the only way that I know of, to effectively get rid of a lot of in-accessible, behind-the-scenes data.
IF keeping the existing BB installation, I would use the BB Settings > Shields & Privacy > CLEAR PRIVATE DATA section, in order to clear everything.
And then set BB to Private Browsing Only mode.
How to do a Complete Exit / Quit of iOS apps; and choices of, Power Off, Soft Restart, or “hard” / “forced” Shutdowns:
Apple iOS - iPhone - completely quit an app:
-https://support.apple.com/en-us/109359
Apple iOS - iPhone - soft restart - steps to reveal the Power Off slider:
-https://support.apple.com/guide/iphone/turn-iphone-on-or-off-iph841379c3d/ios
Apple iOS - iPhone - complete, “forced”, “hard” restart:
-https://support.apple.com/guide/iphone/force-restart-iphone-iph8903c3ee6/ios
Apple iOS - iPad - “forced” restart:
-https://support.apple.com/guide/ipad/force-restart-ipad-ipad9955c007/18.0/ipados/18.0
After startup of the iOS device:
IF keeping the BB installation, disable BB Private Browsing Only mode, if you wish.
IF BB was completely deleted, a fresh BB install.
PS. I recommend also maintaining a 3rd party password manager. ← In order to avoid getting into a “lost my passwords!” mess. And / or use the iOS Passwords app for additional storage.
