Problem with my sound levels only on one website
When I log onto X on brave, even at 100% volume, I can’t hear anything. Like it’s very feeble. My other websites like YouTube and Spotify are working on Brave just fine. X is also working properly on my other browsers. Is there anything I should do to get my volume up just on one website?
Just wanted to add that when i open a guest profile the volume is normal.
[Version 1.75.180 Chromium: 133.0.6943.126 (Official Build) (arm64)]
@haylwoods if you check and it works in private window, then it generally narrows down the issue to be either your cookies or an extension you’re using. You’d have to decide which of the two you’d want to mess with first. Either disable extensions to see if it makes a difference or clear your cookies.
If you try in private and it still has an issue but it works well in a guest or new profile, then it suggests it may be something you changed in your settings.
For now, I’d try to look at the idea of checking your extensions and/or cookies.
