Problem with Leo in the sidebar - inability to copy text and conversations disappearing when changing webistes
Hey,
The first issue I encountered with Leo in the sidebar is a problem with copying content. When attempting to select a response or use the dedicated “copy” button that appears next to code, the content doesn’t get copied to the clipboard.
I haven’t found any patterns for when this occurs, but it happens quite frequently.
As a workaround, I use the button that opens the conversation from the sidebar in a new tab, and then copying works correctly.
This is especially frustrating when I need Leo to work with me on a specific webpage. Having to open the conversation in a new tab just to copy something unnecessarily complicates the workflow and is simply frustrating.
I would like to add that refreshing the website does not help, because it refreshes the website I am currently on, while Leo in the sidebar remains the same.
Brave Nightly Brave 1.88.63
The second issue I have concerns disappearing Leo conversations in the sidebar when switching between websites.
When I have Leo open in the sidebar and start a conversation while on website example.com, the chat remains active even as I navigate through different pages within that site.
However, if I switch to a completely different website (e.g., from example.com to another-site.com), the conversation disappears from the sidebar, and I have to manually find it again in the history.
Is this intentional or a bug?
To be honest, it’s quite problematic. If I’m working on a case in Leo and need to change pages to go to another source, the chat disappears. This is annoying for the user, especially when you’re in the middle of writing a message. :frowning:
@wtab thanks for flagging. I’m unable to reproduce issue #1, the copy button is working as expected for me. What OS are you using? What’s your selected model in the chat? Thanks in advance.
cc’ing @ste for another set of eyes on issue #2.
1- I use Windows and macOS, but I noticed the problem on Windows because that’s where I mainly use Leo in the sidebar.
(I will try to run some tests on macOS and let you know if the issue occurs there as well).
So far, I have not found any pattern or rule that causes the issue on Windows—it just suddenly appears while I am working.
I perform many operations in Leo, in different orders, so it is difficult to identify what causes the issue.
How I use Leo on Windows:
  • Please refer to the specific page I am on (it is a dynamic website - a company messenger with different channels, I get a lot of notifications - maybe that matters?)
  • I join the chat as a source of websites that are locally opened PDF files (the files sometimes have up to 200 A4 pages)
  • I use shortcuts (/) in this, I ask that certain sections of the response be written in code form
  • I work on several browser windows within the same Brave profile
As you can see, there are a lot of variables - I will try to monitor this more closely, but for now I don’t see any specific dependencies.
Once I figure out the pattern of when the problem occurs, I will let you know. :slightly_smiling_face:
Copy - Paste . . . related?
It is worth noting that you appear to be using the Nightly build so bugs are expected. That said I’m not seeing either of these issues on macOS or Windows when using Leo AI.
@wtab I’d be interested to know if you see this same issue in the stable build of the browser?
I’ll test it and let you know :folded_hands:
1 - I managed to generate an error (copying the code block in Leo’s response and the text by pressing Ctrl + C does not work)
When I click the “Copy” button next to the code block → an error appears in the browser console:
What I did:
  1. I was on the company website, where the correspondence with the client was located.
  2. I selected the “Open Leo in the sidebar” button.
  3. In the second browser tab, I opened a PDF file (143 A4 pages).
  4. I started a conversation with Leo using two sources: the company website (point 1) + the PDF file opened in the browser (point 3).
  5. I used a shortcut (/) based on Claude Sonnet, which was supposed to prepare a draft message to the client in the form of code based on the correspondence with the client and the attached file (to make it easier to copy)
  6. After Leo generates a response, it is not possible to copy any content from Leo Ai, and the error shown above appears in the browser console
I would like to add that the answer generated by Leo AI is completely correct, which means that it found the relevant information both on the attached website and in the attached PDF file.
Do you have any idea what might be causing this problem?
