I have problem in remember my login information in almost websites, which mean when i try to login website like socials or forums and insert my username and password and check the square of (remember me) to quickly login and after I close the page and try tomorrow to open it, I find that page of social or forum ask about insert my username and password again to login, so what is the problem?? i need help
Using a Brave Browser Private Window at login sites, can cause the issue. Also:
According to Brave Search (Answer with AI):
The most common cause for the Remember Me checkbox failing to persist in Brave Browser is that the browser is configured to clear cookies and site data when it exits.
This setting overrides the website’s login token, forcing you to log in again every time you reopen the browser.
To fix this, you must ensure that cookie clearing is disabled in your settings:
Navigate to
brave://settings/clearBrowserDataand select the On exit tab. -
Ensure that Cookies and other site data and Passwords and other sign-in data are unchecked.
Additionally, go to
brave://settings/cookiesand ensure that the option to Clear cookies and site data when you close all windows is disabled.
If the issue persists after adjusting these settings, check for one of the following secondary causes:
Shields Settings: On specific sites, the Shields icon may have the Forget me when I close this site option enabled. You must toggle this to Disabled in the Shields panel for the specific site.
Extensions: Third-party privacy or ad-blocking extensions may be configured to auto-clear cookies. Temporarily disable extensions to test if one is causing the conflict.
Site-Specific Allowance: In
brave://settings/content/siteData, ensure that Allow sites to save data on your device is enabled, as blocking this globally will prevent login persistence.
(AI-generated answer, by Brave Search. Please verify critical facts.)
Thanks for your answer, I checked all this steps and do it, waiting to see the result if it success or no and I will tell you
