Problem at iOS Wallet
Hello good afternoon, I wrote to you because for a couple of days several friends who use iOS devices tell me that the wallet does not work for them, since when they try to connect it anywhere it tells them that they are in the ‘test network’, which is not true, and something that does not let them change in any way.
It seems that the problem comes in its latest update (September 2025), Please check this
Hello! Thanks for reaching out.
What Brave version and iOS version are you experiencing this on?
What dAPP or Web3 site are you attempting to connect to?
What is your default wallet set to at brave://settings/web3
Thanks!
This looks to be the same issue on Chrome for iOS. The site is forcing the use of MetaMask and does not redirect to the self-custody wallet correctly.
So, what proceeds? Can we users do something, or do we just have to wait for your DEVs to fix the problem? (If so, do you have an approximate date to fix it?)
Thank you in advance for answering the question
Unfortunately, I’ve attempted to connect on iOS with 3 other self-custody wallets and none are successful. This is likely an issue with the way wallet injection is setup on the site. I would suggest reaching out to the Habbo team and letting them know the issue.
https://help.habbo.com/hc/en-us
Thanks!
It’s quite complicated to deal with Habbo support. They redirect me with you again, telling me that the bug is in your version of Brave available in iOS 26, since before updating it could be accessed normally, just like in Android it is still possible to access, sign, etc
I hope it can be solved somehow, and I don’t have to go around in vain.
I remain at your disposal in case I can help with anything, or can I communicate something specific directly to the Habbo support team.
I sincerely apologize for the trouble.
To clarify, this doesn’t work with the MetaMask app on iOS 26 either.
Can the Habbo team provide any example of a self-custody wallet that works in iOS 26?
I tried with Rabby, Base, Rainbow, and Brave wallet as well. None of them worked for me. This is very likely an issue on their end if I can’t get any of these wallets to work with their site in iOS 26.
Let me know if you have any further questions. Thank you!
Hi Evan,
I’ve kept getting reports from friends who were using Brave on iPhone and are having this same problem. But for some reason, I can continue to do everything normally with my Xiaomi (android), isn’t it possible that your app has not been able to adapt well in that aspect? Because I do connect to where I want with your wallet.
Check it out, I think it makes sense
Anything I’m here at your disposal to help
