Brave browser doesn’t remember print quality setting and also is not using Windows printer preferences quality setting
- Printer preferences quality set to 600dpi using Windows Settings app.
- Open Brave browser and print a page, Under print dialog-> More settings however, printer quality shows 300dpi (lowest setting)
- Change quality setting to 600dpi. Print is successful at higher dpi setting.
- However, ‘later’ it reverts back to 300dpi. It does not revert after brave restart or laptop restart so I’m unclear at what point it reverts.
Not applicable
Brave print settings should reflect Windows printer settings and/or remember Brave printer quality settings
Frequently but intermittently (I don’t print hard copies very often).
Windows 10 Pro build 1809
Brave Version 0.62.51 Chromium: 73.0.3683.103 (Official Build) (64-bit)
Is it possible that the printer quality settings are not ‘remebered’ when a Brave update is applied?
