Briefly describe your issue: Im only receiving new tab ads and not even a single pop up ad since almost half a year. Already raised an issue then, but got no response. People said it was location problem, im receiving many pop up ads on my phone, but not a single one on the laptop. Ads are also at max (10 per hour)
What Operating System and Brave version are you using (Menu --> About Brave)? MacOS. Brave - 1.31.91
Is your browser wallet currently verified? (yes/no) No
What date did you verify your wallet? N/A
Have you been able to successfully receive payments in the past? N/A
Are you in a supported region (see here for list of supported regions)? Yes
Does your device pass the SafteyNet check (Android only)? N/A
Have you manually turned off Auto-contribute on all of your devices linked to Uphold?? I turned off auto contribute, but not linked to uphold.
