Description of the issue: Unable to pin Brave to taskbar with context menu functionality (right click taskbar icon >> “Open in new tab”, “Open in new window”, etc.)
Install Brave on Windows PC
Attempt to add to task bar via settings “Get Started”>>“Pin to taskbar” (fails)
Pin via manual workaround- ‘click and drag’ method (due to above bug)
Right click icon pinned to taskbar
While the manual workaround exists to add a shortcut to the Windows taskbar, the shortcut only serves to open, pin/unpin, or close the application. It does not support a helpful context menu. When manually added in this way (since the prescribed method of adding via Brave settings fails), the only context menu options are limited. Screenshot below illustrates limited options>> “Brave” (opens new window), “Unpin from taskbar”, or “Close window”.
Here is a thread that was closed without actually solving the issue: "Pin to taskbar" setting not working - #5 by Mattches
Brave Version( check About Brave): 1.94.117
