Pin extension in incognito
I know well how to pin an extension - but in incognito I can’t pin it properly even if the extension is active. What happens is very annoying; clicking the jigsaw puzzle and then clicking the extension (which has a greyed out pin) only “quasi pins” it up in the menu but then one is apparently supposed to only hover to get the extension dropdown. If I click the extension button it instead hides back in the jigsaw menu.
I want it permanently pinned in menu bar.
Help please
So, do you want different pinned Extensions on your Normal Browser and different one on the Private Tab or you want both of them to be the same?
Extensions can’t be pinned/unpinned in a private window. Whichever extensions are pinned/unpinned in a regular window will show as pinned/unpinned in a private window, given they’re allowed in private window.
Aaah, thank you for your replies. Yes, what I would want is for a extension to show in Private which is not shown in normal window. IMO it makes sense since I have particular uses for Private vs normal mode so obviously(?) I have different needs in terms of extensions and extension accessibility.
How would I go about to make this as a feature proposal?
Again thank you!
You have 2 options:
  1. Open a thread in the Brave Feature Requests category → https://community.brave.app/c/brave-feature-requests/desktop-requests/63
  2. Open a Github feature request → https://github.com/brave/brave-browser/issues/
