@Ixotic
Please edit your Original Post (“OP”) above, in order to include:
- Brave Browser version numbers
- Operating System version numbers
On the chance that you are using Brave Browser for desktop / laptop computers:
In a Brave Browser New Window, go to the On exit tab at brave://settings/clearBrowserData ← There, DISABLE the following:
- Browsing history
- Cookies and other site data
- Cached images and files
- Passwords and other sign-in data
- Autofill form data
- Site and Shields Settings
Click the Save button. Then Exit / Quit Brave Browser. Restart your computer.
How to Back Up Passwords that are stored by Brave Browser
Scrolling down the webpage at:
https://support.brave.com/hc/en-us/articles/360018185951-How-do-I-use-the-built-in-password-manager
A note states:
“Export Passwords - Selecting Download file will export all credentials you’ve saved in your browser as a .CSV file onto your system. Note that anyone who has access to your system will be able to open and view this file, so it is recommended that you delete this file once you’ve used the file for its intended purpose.”
Tips on how to encrypt that .CSV file:
Be sure to safely store a copy of that CSV file on an external drive.
Site Settings Details and Permissions Tips - When Visiting a Website
IF Brave Browser can reach a website, then you can access that website’s Site Settings details page by clicking on the tune icon that is located immediately to the left of the http at the left end of the URL address field
Notice that the brave://settings/content/siteDetails?site=https%3A%2F%2F portion of the Site Details links, are a constant, a fixture if you will . . . followed by a hostname or domain name, such as:
www.youtube.com
youtube.com
So, for example, if Brave Browser has trouble reaching the website of interest, you could use a Brave Browser New Window and go directly to (using www.youtube.com as an example): brave://settings/content/siteDetails?site=https%3A%2F%2Fwww.youtube.com
Use either method for reaching the Site Settings, to:
- adjust the settings
- clear/delete the site’s settings
- reset the site’s permissions
but of course, the second, direct method, here, is handy when the first method (tune icon ) is not possible (ie site unreachable).
Tips regarding Brave Shields:
I have more success, with:
- Brave Shields UP
- Either Allow All Cookies or Block 3rd Party Cookies, but NOT Blocking All Cookies
- Allowing JavaScripts from specific sources, but NOT Allowing All JavaScripts
- Trackers & Ads treatment: Aggressive (at first), and then incrementally relaxing that setting
- Fingerprinting (aka footprinting) blocking: Strict (at first), and then incrementally relaxing that setting
I almost NEVER use:
- All of Brave Shields UP
- All of Brave Shields DOWN
Shields Basics
How do I configure global and site-specific Shields settings?
How do I use Shields while browsing?
