This is just open thought, not well written. Need more memory control
- larger the tab quicker inactivity.
- above 50mb, don’t load or load with warning
- above 100mb, inactive after 10 sec
The memory management comes from upstream chromium, anything like this would need to be from upstream. Memory Saver in brave://settings/system does help with most issues.
Having hard limits also can be an issue with users with more ram, which probably why memory saver is a bit more flexible than “X mb limit”
