Open Split View with SHIFT+Click combination
I have been away from Brave for a couple of years while using Arc, and despite it’s great UX, a few weeks ago I decided to come back to Brave after realizing that Brave just provides (almost) everything I really need while being less “busy” with few tabs on top instead of the vertical tabs ! :hugs:
After coming back to Brave, I noticed the “Split View” – one of the features I used the most on Arc, and while it’s not very hard to right-click a link to open the split view from the context menu, it would feel awesome to have a SHIFT+Click “hotkey” to open it right away.
Having such a hotkey would help making the split view feature easier to use, IMHO.
Perhaps it is just me, but I found it much simpler and easy to use if I can combine a hotkey and a mouse action to trigger a feature.
Your feedback on this is much appreciated! Thank you a lot!
